Hey folks,
I'm the original owner of my '98 GT and just noticed the other day that anything over 5K RPM I'm getting the rattling/pinging from the engine. I don't know how long I've had this problem because, as my daily driver over the last 21 years, this car never sees anything more than 3K RPM during my commutes. The car starts up easy, idles great, has excellent throttle response, pulls well, and does everything like it did back in 1998 except for the rattling/pinging above 5K. I never would've noticed if it hadn't been for the pushy Range Rover in the other lane.
In any case, the car's only mods are a K&N air filter element and a PI intake. After searching around the 'net and this forum I tried moving from 87 to 89 octane, cleaned the MAF sensor, ran a half can of seafoam in the gas tank and changed the fuel filter, and it is still pinging. There are no engine codes and the spark plugs (gapped to factory specs) and wires were changed to Motocraft brand pieces just under 20K miles ago; the car currently has 128K miles on it. I replaced the fuel pump back in 2006, and my fuel pressure gauge reads 30lbs at idle, and holds that pressure for at least a half an hour. I have always used synthetic oil but only change it when it gets to 7500 miles, which is only once a year and a half or so; I don't drive very far at all in this car.
I've read about seafoaming, top-end cleaner, and trying 91 octane, the highest octane available to me, but I'd rather not do that because as we all know the car should run fine on 87 and I'd like to genuinely fix the problem, not just band-aid it. Any suggestions or ideas are greatly appreciated, thanks in advance..
