rz5.0
Really!!. What is crap about it 40 over.. 308.
86svo- I would have gotten a second opinion on that rotating assembly and the people that assembled it.
There are SEVERAL people running 347s and 331s on stock blocks and boosting them or running a high CR and spraying them. Its all in the builder and the quality of their work.
ok so im starting to mod my 95gt. as the plan goes it will have a 331 stroker with gt40 heads and intake, the heads and intake will be ported polished and gasket matched. the heads will be fitted with new valves, springs, roller rockers. but after all is said and done i want to add a supercharger or small turbo. i want to push out over 400whp that is streetable. i dont want a street/strip car.
my questions are.
1. what cam is good for a setup like this? i dont want alot of thump. this is not a strip car.
2. what size injectors?
3. whats a good sc to go with that isnt really big but will give me enough power? im not looking to cut out headlights but i want some head snapping when i hit the boost.
you said it your selfThanks but im pretty dead set on the 331. ive always wanted one and i wont be happier any other way.
1. I would stick with either the stock cam or something near it in spec. Being as you are changing nearly everything else I lean towards a custom cam with emphasis to be stock like in idle characteristics. Being a 331 you can go a little more aggressive with the cam and still be mild. Ed Curtis would be my first call for a specific recommendation.ok so im starting to mod my 95gt. as the plan goes it will have a 331 stroker with gt40 heads and intake, the heads and intake will be ported polished and gasket matched. the heads will be fitted with new valves, springs, roller rockers. but after all is said and done i want to add a supercharger or small turbo. i want to push out over 400whp that is streetable. i dont want a street/strip car.
my questions are.
Id like to see a stock 302 make 350 hp. NOT GONNA happen. Your not gonna add 150-175 horse with a blower or turbo sorry but your sadly mistaken. a stock 302 makes 215 to 245 depending on the motor, add a blower @ 7 psi (+75-100 hp) and your only at 290-345. Turn up the boost and add ported heads and intake and you can get right at his power goals.
To the OP, GO WITH THE 331!!!! It will hold 10-12 psi just fine and thats all you need to hit your goal with the parts your wanting to use. The Vortech and Procharger Kits are respectable and a pretty forward install. You wont need anything bigger than the 42 lb injectors and a 255 LPH pump.
yep agreed and no one will know if its a 302, 306, 331, 347..... but you
