rz5.0
the pbr are the same for the v6 and the gt stock 11inch rotor for the both too.
I guess.. I rarely hear them been refered too as v6 brakes..
Just go to your local auto parts store, order 2 calipers with brackets and hardware for a 97 Cobra. These should be around $50 each, then order 2 rotors for the same car (mine were $60 for the pair), then get 2 lines ($20 for the pair), and some pads of your choice (I went with EBC Redstuff for $100). There you go.. Better than factory Cobra stopping power for under $300!
You also have to grind your spindles to get the calipers on.. Other than that it's all bolt on
I yet to find a part store that carries the cobra front bracket..
No grinding need it on the cobra swap..
Ug. I know I've taught you guys better then that!
If you're gonna do the setup, you need the rears also plus the Cobra MC. If you don't do all of it, I would just go with a pair of 99-04 PBR calipers like in the ebay link. You'll have to grind a little, but not much. Leave everything else as is, and get some QUALITY pads. Cannot stress this enough. HAWK, Carbotech, EBC, Porterfield, take your pick. But don't do a race pad, street pad only.
Also, IMO, if you really have a mushy pedal, calipers won't help that. Your issue is either worn out spongy soft lines, air in the system, brake fluid that's never been completely flushed, or crappy pads. Or a combo of the prior.
So take your pick, I would probably get the calipers from RockAuto, this set is $70 for the pair brand new without a core: Ford->Mustang->2000->4.6L->Brake/WheelHub->Caliper
Then shop for some pads, saferacer or ebay. Expect to pay $150-200 for a set of 4 good street pads. Find some braided lines, or at minimum replace your front soft lines. Valvoline synthetic brake fluid (DOT 3/4), and bleed until every corner is as clear as the new fluid.
Id pass on both of those and look at the North Racecars brake solutions set up even comes with a maxmotorsports stainless lines and cheaper than lmr. Another plus is no sve writing and a bare caliper so you can customize them to your liking without having to strip off powder.
link http://www.northracecars.com/Brakes.html
I know, thats not a big deal. I wasn't planning on changing the rotors, mine have like 3k on them so no reason too. I planned on SS lines anyway. I saw the setup you linked me too, pretty expensive but everythings there. Appreciate the help man!
I think I'll get the ones off RockAuto. Already powdercoated red too so thats a plus. Found similar ones on summit but unpainted. Sounds good. Can't wait to buy the parts and do the swap. I'm not worried about grinding the spindle, I got a dremel so I could try that out. Thanks a lot RichV
If you're talking about these:
That is not a good deal honestly. $45 without a core EACH?
I paid $50 shipped for my entire PBR setup minus rotors.
You're looking at like 150 for completed calipers with shipping. That's Cobra brake territory.
I wounder if AM price matches... LOL
aren't they like a 10.65 or 10.8 rotor not 11"
Auto zone 44 each...
correct since the 94-95 spindles are different then the 96
hmmm my local autozone carries them.
correct but he was referring to the PBR dual piston setup just didn't clarify
i dunno rich my Gt master cyl with cobra fronts and new Valvoline syn fluid is amazing. And works just fine.
i agree with the lines as I went with Goodridge SS lines for the front.
I say just hunt your local CL for a set of cobra calipers. They'll pop up.
Just do he PBR caliper with ss lines you'll be good.
Thats $70 for both right there.. It comes in a pair. And theres a core charge like $25 or something. I'd rather not buy used, just the way I am. I priced everything out. PBR Front calipers (already powdercoated red) with brackets, SS lines, hawk ceramic front and rear pads, $313 for everything.. Cobra calipers are what 250+ for the fronts? Tack on 13'' rotors, lines and pads thats atleast another 250.. Oh and plus I'd need cobras for the rear too.. The pbr swap I only change the front calipers, lines and pads all around.
Damn i was off by a bit hahaIncorrect 10.87
O.You don't have to run cobra rears......!!!!!!! I've know. Probably a dozen people that have never run cobra rears and even a Gt master cyl. That stuff isn't needed!
That is incorrect.
If you're set on not doing cobra brakes, at least don't go blowing all your money on calipers.
Why would you need to do the rears too? The rear brakes only provide like 1/3 of braking power.
O.
Oh wtf that blows.. So I'm better off getting the unpainted ones off Summit for $39 each. Thanks for pointing that out, I would've ordered one like an idiot lol.. I just assumed you'd need to do the rears, thought the fronts would overpower the rears.
Yeah i'd say so. Painting them is easy and cheap especially if they're not on the car.
And when you add them to your cart, it adds them both so you would've noticed sooner or later.
Yeah its pretty easy for sure. On the car wasn't bad, I painted em with a brush lol.
