T45 tailshaft bushing and seal replacement
1bad95
Anyone ever replaced the tailshaft bushing and seal on a t45? Getting some noise and vibrations from the tailshaft area of the trans and i believe this could be the culprit. Driveshaft has a good amount of play where it enters the back of the trans. Havent found much info on how to tackle this and if i can just pull the tailshaft of the trans while still in the car if its needed to come out. Any info or tips are greatly appreciated!!
96blak54
Lawrenceburg Kentucky
Like this...lol. This guy wanted a roller bearing inplace of the bushing, but to answer your question, yes both bushing and seal can be replaced. And you might be able to dismount the tailshaft housing with out dropping the entire tranny. Their is enough room to get the bolts out. Ive never done this, because the tranny had to always come out for other reasons.
1bad95
Thanks 96! So I'm assuming the tailshaft def needs to come off for the bushing replacement? Roller bearing def seems like a good idea too
Sent from my XT1080 using Tapatalk
96blak54
Yes...Tailshaft housing will need to come off to replace bushing. Send it my way with your desired bearing of choice if you want it like the picture.
1bad95
It's getting ready to go on Jack stands for the winter and I'm gonna get it apart. Might have to go that route. How much to machine it for a bearing?
96blak54
Idk.... $50hr for 2hr job.... $50bucks...lol. The bear will probably cost more. Ill check with the guy and his bearing part #. Its Jacob Lambs ...if anyone keeps up with drag racing. Ill report back.
1bad95
OK thanks man! I'll def let you know. Might try to he new. bushing 1st but I definitely like having this option available
Phoenix0783
Is that a drop in replacement or is machining required?
1bad95
im pretty sure that it needs to be machined to fit the bearing
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
This is awesome, I will have to go this route. Let me know when you get the part number on the bearing and if you want to do another one we will talk business when the time comes.
96blak54
Will do. I also offer machined pullies, flywheel lighting, rear gear ring lightning, head decking, ...really just about any type of machining. You can think it, ill try it.
DriftCafe63
