t56 swap bellhousing ? 94 GT
daves94vert
Still gathering parts for my cobra t56 swap. I'm on the bellhousing search. Is our tranny fork at the 9 O'clock position or the 7 O'clock position. Looks like the 7 but trying to make sure. Will my stock sn fork work or do I need a fox fork? Thanks.
Kennebell 2.1
Va
Fork
Do u mean clutch fork I did the t56 swap in my 98gt if u have any questions I'll see if I can help u
Kennebell 2.1
Va
Yeah I used same bell housing works great anything u don't know u can go 2 d&d performance they specialize in the t56 swap
Suspect
ATL
what ryan said. also using a steel quicktime bell. stock fork with weight taken off.
daves94vert
Ok. Quicktime RM-8031 bellhousing(clutch fork at 7 o'clock)
03-04 cobra driveshaft with a hybrid u joint to adapt to 8.8 axle
aje trans mount
I read about a speedcal. Whats that for? speedo reading? and the reverse lockout. Where's it located and I think I'm supposed to change the spring?
aje trans mount
I also suggest a driveshaft spacer with the cobra driveshaft as it's a bit short.
the speedcal is so you can get the proper speedo reading, the newer trans use a different style reader in the trans (not a gear) and it reads WAYYY too high with our stock setup.
the reverse lockout is on the side of the trans, you can either wire it to a 12v source when you want to move it to reverse or just use a little muscle and push it past the solenoid. They also make kits to release it automatically when you're below ~3mph.
SMOKEDYA
Tucson Az.
I used a mcloud and had to cut and reweld where the clutch fork goes since they are only set at 9oclock. Quicktime is the only bell housing that has it properly positioned for our cars.
Vmarch
