Teal 1995 Mustang GT Supercharged Build
A
Paint black to hide the oil leaks… lol
Picked up a summit stage intake, it’s a copy of the stealth intake. Should work good with the n41 cam and gt40 heads. Since this is a weekend toy/track car, the carb set up will be fine. I plan to throw a 150ish shot on it. If it holds up, I’ll probably toss a single plane on it and it it with a 200ish shot…
A
Intake cleaned up and painted.
Intake and power steering bracket on. Later on when I get the tubular k-member, I will probably switch to foxbody front accessories.
The alternator bracket on and painted. I'll finish it all up tomorrow, and maybe get it set in the car tomorrow evening.
A
And yes, the paint work isn't the greatest... But at least it's clean and looks better than it did.
I think it looks pretty good. It’s awesome what some silver paint can do.
Just fyi, if you end up having charging issues, make sure you clean some paint of a bolt for the alternator and run a ground strap to it. Gotta have a good clean path to ground.
A
It's good enough for this car... I'm hoping I can spray this thing into the 6's (1/8th mile.)
Alida81
