I'm running a 2001 GT tank with the pump hanger drilled out of the bottom and a kurgan fuel hat. The thing I had to deal with most was the evap emissions lines and the extra holes in the tank. I had one hole welded closed and also had a fitting welded to accept the smaller line on the filler neck. Also, the fillers pipes are different sizes, the 94 is larger. It's not plug and play but it can be done. I have pics I could post if you want to see what I'm talking about.
