cheebs127
Hey all,
Im new to this forum but Ive done plenty of lurking and reading before actually signing up. I've always loved the SN95. I had a 96 V6 in high school that I started to Cobra swap but unfortunately I had to part out the project when I enlisted. Fast forward seven years and I'm back at it again chasing an old dream.
This car started out as a 1997 V6. I bought it and a 98 GT for $800 with the original plan being to swap the GT into the 97 and then do a built Mark VIII motor swap with some sort of power adder. Pretty much a swap in a swap. I changed gears a few months in once both cars were torn down and I came across a good deal on a whole 03 Cobra that had been wrecked. So thats where Im at now. I have a complete Cobra in the garage and the 97 is awaiting some torque box reinforcements and subframe connectors before I start swapping over wiring and fuel systems.
My goal for the car was mostly street use. I'll probably take it to the strip a time or two just to see what it does and maybe run it against my dads 65' Fastback just for the hell of it if I ever take the car home. I decided to keep the 8.8 solid axle. I had already picked up everything to build the axle and rear suspension for whatever I was going to throw at it before the termi came along. Below is a list of parts Ive compiled for the build.
Front Suspension/Brakes
-Team Z autocross k-member
-03 Cobra rack w/ offset bushings
-Strange adjustable struts w/ coil over kit
-MM caster/camber plates
-Modified spindles + custom bracket to accept 14 inch rotors and 2015+ 4 piston calipers
-13.8" rear rotors and 2015 calipers with custom brackets (in design phase)
-Maximum Motorsports steering shaft
-Steeda bumpsteer kit
-ABS delete
Chassis
-MM subframe connectors
-Team Z bumper support
-Team Z radiator support
-Maximum Motorsports strut tower brace
-UPR shock tower brace
-Trunk Battery relocation
Rear Suspension/Axle
-03 IRS
-Diff Brace
-FTBR bushing kit
-FTBR toe link
-FTBR sway bar end links
-H&R race springs
Engine/Exhaust/Fuel
-Steig Stage 3 blower
-2.76 Pulley
-LFP single blade TB and elbow
-FRPP 60lb injectors
-KB Boost-a-pump
-SCT 2600 MAF
-JBA Shorties
-Bassani catted x-pipe
-Bora Stinger cat-back
-13' GT500 heat exchanger with twin electric fans
-Canton battery location heat exchanger reservoir.
Transmission
-Spec Aluminum flywheel
-Spec Stg 3+ clutch w/low pedal option
-Tremec 26 spline input shaft
-MGW short throw Shifter
-Stifflers Transmission crossmember
Interior
-Braum Elite Series Seats
-Autometer clock and instrument cluster pods
-Speedhut Oil Press., Coolant Temp, Volt, and WB AFR
-Painted clock pod, radio and shifter bezels to match exterior color
-ABS delete
Chassis
-03 IRS
-Diff Brace
-FTBR bushing kit
-FTBR toe link
-H&R race springs
Engine/Exhaust/Fuel
-2.76 Pulley
-KB Boost-a-pump
-SCT 2600 MAF
-JBA Shorties
Transmission
Interior
