Dood, your car looks great! Moving along nicely with building it. I like how you are selective with what components installed.....u got direction!
Any plans to run the big track?
The NT05s are great tires. I've seen guys kick ass with them on track. I gotta see this 315 on the fronts your planning though lol. I plan on doing it in the future but I know what awaits me and I'm not ready for that.
We all know the door panel cannot handle the death grip!
Nice work!
What are you using for a drivers seat? I wanted to get a fixed bucket, but wasn't sure if I could safety use the factory 3 point...
It's a Corbeau FX1 Pro. A little skinny, but its comfortable enough for 3-4 hour drives.
After reading a bunch of articles and forum posts, most people say that it is safe to run factory 3 point belts with this type of seat. Basically the lap belt needs to strap across your pelvis to prevent injury. If you don't thread it through the bottom harness holes on the right and left side it will run too high and contact your abdomen, which can injure your soft tissues/organs in the event of an impact. Just thread the belt through the pelvic strap holes and you're good to go. I've been running mine like this for 2+ years.
Another thing to consider when running the stock belts is the seat brackets. New edge cars have the factory seat belt buckle attached to the seat frame and 94-98 cars attach directly to the trans tunnel. I ran into this problem when I went to install 94-98 Corbeau brackets in my car. I ended up ordering Corbeau brackets specifically for the New edge and it came with the correct stud to attach the buckle. Learn from my mistake! lol
Correct, I'd like to run the seatbelt through the harness holes so it actually wraps around you. My issue is on the buckle side, how are you clipping it through the hole? The buckle appears to sit at the same height as the bolsters.
I knew about the brackets, I've played with both interiors and remember the buckle attachment difference
