You should of hit me up. I have a catless x sitting in the garage that won’t be needed anymore.
ah see and my birthday is next week. I expect you to double what I got you last year....You should of hit me up. I have a catless x sitting in the garage that won’t be needed anymore.
how do I do this?Scott have you verified that the stator is sending signal from the dizzy?? It controls fuel and injectors as well. When they start going bad they do stupid stuff like this.
how do I do this?
I replaced the harness going to the coil just because I think its the last original harness that was on the car and maybe it was causing the no start. Didn't help any though.... After a lot of thought I also decided to make a mount for the X-pipe to lock into the factory center position. There were two tabs on the pipes that were in the perfect spot to put it and not having one was my only complaint about the pipe.
I got some 1/8" angle iron and made 4 cuts, drilled 4 holes and rounded off the edges and put a coat of paint to finish it so the stock mount could attach to it.
I am happy to say it bolted right up and I needed to use the jack to push the pipe up just a tad to get the mounts on but I like it nice and tight...
The only thing keeping it off the road now I am afraid to say is my vanity, and sore back. I have been taking the time its up on stands to finish cutting the paint on the bottom 1/2 of the car and its killing me. Even with it up in the air I have 2 compressed discs in my back that can get inflamed really easy from work like that(bent over rubbing). Its sooooo close......
if that were the case you would be the first to knowStop lying. Your boyfriend is why you were bent over.
Now get that thing on the road!!!! [emoji23]
Finally got the new battery mount welded into place, got all the wiring ran and hooked up. Now its cranking the motor faster, but it is not firing up any faster. I still need to crank it 3-5 times for 5-6 secs each time to get it to do anything. Once it fires I can turn it off, and then start it right up no problem. I have fuel pressure, verified spark with a timing light and tried all kinds of combinations for more/less air/fuel while cranking or just after but I am just not sure what is going on....
