I swear if I didn't have bad luck I would have no luck. I ended up having an issue with a few switches where they did not work or worked off and on. I was afraid that during the fitting of the pieces with some sanding/fitting that I got enough dust into the switch that it did not work. I had the correct power/ground at the harnesses that plugged in so it had to be the switches I thought. Talked to the manf and they were really cool to send a new set out for free even though I told them that it was my fault. I got the switches in yesterday and finally got them in today and found I was still having the same issues. After a really close inspection of the harnesses that plug into the switches I found that the pins in the harnesses were not aligned perfectly and when pushed together it was pushing the harness connector just far enough back that it was not making contact. After spending a little time to figure this out and then more time to correct it I finally got to see it all together, in place and working. But I did switch to a different looking switch that I think looks better myself. Now I can finally put stuff together and.....
