The official dyno result thread
Status
Not open for further replies.
Nuttinbutcrumbs
Between the Red and the Rio
95 Mustang Gt
306
E7 heads
Comp beehive springs
.512 lift cam on in/ex 281 duration
Ported HO lower intake
Stock Upper intake
Stock throttle body and MAF
19# injectors with FMU
Stock fuel pump with Vortech's T-rex inline pump
Vortech V3 6-8 lb boost
Stock headers
Stock h-pipe with pre-cats removed and aft cats replaced w "high flow's"
Forza Flow chambered mufflers
MSD ignition
22* total timing
All smog and cold a/c
332 rwhp 334 rwtq
ReplicaR
331 cid
185 AFR Heads
FTI Custom Spec Cam
TFS R Intake
Short Tube Headers
Off Road X pipe.
360 rwhp 366 rwtq
its not that we do not want to share but I have only had it on the dyno once and that was 8 yrs ago and I have no idea where it went to after the move back to the Midwest myself. I have not decided yet if I am going to the dyno or to go the megasquirt to tune myself. There are more people going that rout as well as by just data logging while driving and having a tune written off of that. Most of us do not want to pay the price for the dyno if we didn't have to and its only really done when a large enough change was made that it needs it. I think there is also a good number of us that really do not care what the dyno numbers are as long as it is running good we could care less what the numbers are.
torch318
From last Thursday but no sheet to share more issues. It did make like 350ish at 4500 rpm though.
Sent from my SM-G900R4 using Tapatalk
Sinned83
MA
This thread makes me glad to have left the pushrod world
Why,, because you have to pay more for parts to gain just as much and possibly less? $4k for a 6-8 lb of boost blower is awful steep.
That's all I have to say about that.
That is true but then remember all the obd2 tuners you saw for new and how many you find sold used. each has its good/bad points.
Sinned83
MA
slightly more than 4k but 450whp isn't uncommon on a 4v
Sinned83
MA
96+ cobra,03-04 Mach, marauder and a couple Others have the 4v. Mod motors are expensive to mod but worth it IMO. I'll contribute soon to the dyno #'s. I'm shopping for cobra cams and LT's. Should be around 330whp
Nuttinbutcrumbs
Nuttinbutcrumbs
What do you drive? What other mods do you have? Would the cams and LT's the big ticket items purchased thus far? Holycrapo! For kicks I looked on AmericaMuscle to see what cams were running. Nearly $1,300!? That's crazy! As far as the "worth it" goes modding" a 4.6 vs the 302, I guess it depends on if the 4.6 is a 2v or 4v. The 2v has just as much "ground to cover" in stock trim as the 302 as far as being relevant in the power department these days but it's a lot cheaper to make 300whp in the 302.
To make 300 rwhp with the 302 mustang it takes in the ballpark of $3k.
If you're telling me that a 4v w a cam swap and long tubes makes around 330 rwhp then that just might be the bang for buck winner of the day.
However the last time I was at the tune shop I saw an old ass worn out fox that was stock except for mufflers make 300 whp on the nose with a used 6-8 lb Vortech kit. This thing was so stock that they had to change the plugs and wires to get a good pull.
Don't Sext and Drive.
Sinned83
MA
I have a Mach but I'm not getting after market cams the intake cams from 96-98 Cobras will give good gains in my car
Z06killinsbf
McKinney, TX
95 Gt
Stock short block
Stock HO cam
Stock Cobra intake
Twisted Wedge heads with 1.6 RR's
60lb injectors
75mm TB
LMAF w/Power Pipe
Hooker Equal Lengths
Vortech V2 @ 14psi
Nuttinbutcrumbs
Nuttinbutcrumbs
Im glad you guys like spending that amount of cash on performance.
That's probably around $5k spent (new parts not used) and he gained around 270 extra rwhp. You gotta remember the poor pushrod guy is only starting with 200 whp or less. But then again so is the '96 GT, throw $5k at it and see how far it'll get ya. I subscribe to mm&ff and I often have to roll my eyes at them. One issue then cover story was "Make 632 Hp The Easy Way!" Well they started with a car with a 400 horse motor and added a $6k blower.
Status
jarthur1995
