These heads won't necessarily need work, I've read quite a bit about them. Turns out they are pretty good quality wise. I was just being general, as are you I'm sure.Any aftermarket head is going to flow more than an untouched gt40 head. Aftermarket is the way to go but like he said the casting probably will have some defects. If you want a cheap pair of heads that you won’t have to touch, afr enforcers or windsor jr are the go to according to people on the corral. With these heads you’ll probably have to at the very least replace the springs and have them worked over to run them.
Exactly, rule of thumb there may be some cleaning up to do.These heads won't necessarily need work, I've read quite a bit about them. Turns out they are pretty good quality wise. I was just being general, as are you I'm sure.
I always wanted to run a set of SVE heads on my 5.0L when I had it, but I didn’t have the money at the time. Keep in mind, you are really going to want a tune to go with these new parts you are installing. It will make the gains way more noticeable.I think im going to go with them as im not looking to break the bank or make crazy power just enough to put a smile on my face. I'll match it up with a very small cam and some rockers. Just hope the piston to valve clearance is good because im reading conflicting information on that.
They came stamped Summit in the aluminum but had AFR stickers inside the box.What brand were they? Summit repackages other brands in their packaging.
Ah so they’re probably afr enforcers then. Those are still good heads but they’re not in the same league as the sve heads.They came stamped Summit in the aluminum but had AFR stickers inside the box.
