domhoff13
Hi,
I am new here I took this '94 GT on trade for a high milage lifted blazer that I had. Any ways it has some problems that need sorted out since I don't really know all that much about ford's, I am looking for some information and I figured this was a good place to start.
As far as the car is concerned it has 126K miles the engine and trans have about 11K miles on them. The guy I got the car off of did nothing to the car except burn the clutch up and park it for two years (roughly 2k miles). He bought the car off of a friend, who also did not build it. The car has no rust, however the paint is chipping and it also needs door pins on the drivers side. The clutch cable is loose at the fire wall, it seems to have a billet adjuster and a secondary clutch cable adjuster. I am not really sure.
Anyways it seems to have the D&D aluminum bell housing for the T56, pro 5.0 shifter, some brand of tubular K-member and sfc's, UPR caster/camber plates, S351 wing (not my favorite I want an S281), eibach drop springs.
For the Engine:
It needs some sorting too, there is a surge at idle and a slight mis, a vacuum leak, a funky change vacuum pressure when it surges, as if the valves are not set correctly. It needs retuned for sure, I am just not sure if it still has the stock computer.
Aftermarket engine parts:
Decent hyd. roller cam - Not sure of specs
Ported Aluminum Heads - Not sure of brand I found the information of who ported them but cant make out the scribe marks with a mirror.
Pro-Flo 75mm MAF
BBK Edelbrock 70mm throttle body
Comp Polymers intake plenum with composite spacer
SVO intake base and Elbow
Crane Gold 1.6 RR
30lb Red top inj.
Ford Fuel rails
STD 4.00" bore
There are a lot of little things that I keep noticing everytime I look at the car that could be worked on. I will keep it up to date or is there a better place for this?
Thanks.
For the Engine:
Pro-Flo 75mm MAF
Crane Gold 1.6 RR
30lb Red top inj.
Ford Fuel rails
STD 4.00" bore
Thanks.
