Top Dead Center
Robert Castanon
So I want to replace my valve stem seals to my 03 4.6. My question is if I set my timing to top dead center before I remove the camshafts. Would I have to find top dead center again, or will the camshaft fall into place with no issues.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
These engines don’t time with top dead center. There is a timing mark on the crank gear that you align with the mark on the chains.
You’re going to want the crank keyway to be at 9 o’clock so all the pistons are below deck. That way you don’t bend any valves when you take the chains off. I do believe there is a good video on YouTube about setting that timing.
R
Robert Castanon
Ok, so once I set timing and remove chains and camshaft. When it's time to putting the camshaft back, will the camshaft sit back the way I removed it.
badass98svt
Did you watch the vid on YouTube? Should answer all your questions
apsmith49921
my advice is 9 o clock, pull the followers, then the cams replace the seals install the cams, time it then install the followers last.
jarthur1995
