Tommy92
Does anyone know a way to install a tow hook for the front of my Mach 1 without having to cut a hole from my bumper?
can always mount an eyelet on your k-member and use a strap..
http://sn95forums.com/showthread.php?56363-plenty-of-updates-to-the-cobra!
this give you any good ideas?
No.. You would have to find a suitable location, drill a hole and secure it with a nut/lock washer/flat washer.. You would have to consider the strap riding up when tension was put on it and interfering with the bumper.
-or-
You could have a bar fabricated that left the k-member, stuck out thru the valence with the tow ring/hook past the leading edge of your bumper.
machs come with fog lights, huh?
Are you looking for tow hooks like for a race car? Something functional I assume, for when you get towed? Do you get towed a lot? Not being a smartass, just don't see anything practical about it unless you load/unload on a trailer a lot or run a racetrack where when your shit breaks they can find a hook and get you back in the pits without popping the hood and what not.
All the hooks I've seen have some cutting involved.
www.racecartowhooks.com
Most mount to the bumper supports.
This style:
You may be able to find something that would be long enough, but remember the pressure that is on that hook when being towed. Specialy turning, would it hold?
Putting anything out the foglight hole like a strap will put pressure on the bumpercover when turning (being towed) but I know it works. I have a axlestrap bolted to the framerail and out the passenger fog hole and it works just just fine, not a looker tho.
Just do what you did with your old mustang and the backup camera in your trunk
A strap will be your best bet. Just make sure it complies to the rules you need to have it for.
I've seen several guys who run the strap out under the headlight, and just tape it down so it doesn't flap all over on the track.
