Trans question.
Fireman450
Hello all.
Im just getting into the SN95 thing. I bought a 94 for my fiancée. Just a little back story, the car was "supposed" to be mechanically fresh. Fresh engine build (origionally a v6 5spd car converted to a 5.0) trans gone through, rear gone through ect. Long story short Im in the process of putting in another long block due to the car jumping time right off the trailer.
Pulled the engine and trans. some one has put some grade 8 nuts between the bell housing and the trans to space it back. by what i have read so far the v6 t5s had a 5/8s longer input shaft, correct?
What is my best action to correct this "rigging" ? i do mechanic work for a living but mostly on older classics and diesels, so im on a bit of a learning curve when it comes to a mustang.
Thanks for any help y'all can give.
Lynn
Sounds like the PO put a fox bellhousing on the SN t-5.
All of the SN (94-04) t-5's (GT and v6) had a longer input shaft. Which mean the bell needs to be longer too.
Welcome to the insanity.
Fireman450
Fireman450
Thanks for the info. It sucks having to go back through what a PO had already done, or attemted to do. Makes me question everything else about the car. but oh well it will be right when im through with it.
Fireman450
Fireman450
Here's the only pic I have of it right now.. besides the carnage. I'll post that in engine tech.
Sent from my SCH-I545L using Tapatalk
lutter94
South Dakota
Here's the differences in clutch fork positioning Fox vs. SN95 bells.
482d1364828706-has-anyone-successfully-used-1994-1995-t5-bell-housing-hydraulic-slave-cylinder-94-95-bellhousing.jpg
483d1364828706-has-anyone-successfully-used-1994-1995-t5-bell-housing-hydraulic-slave-cylinder-foxbody.jpg
Fireman450
Fireman450
What's the biggest difference between a 3.8 sn95 bell and a 5.0? Starter location?
Fireman450
Fireman450
Smaller clutch with the 3.8 bell?
Tom76
