Transmission/clutch chirping
Dudeguysn95
Los Angeles
Hi so I just bought myself a 1994 mustang GT and I've noticed that when I drive it and I have my foot off the clutch it like chirps and squeaks a lot and if I put the clutch in at all even if I just barely lay my foot on the pedal the chirping stops. Any ideas on what the problem could be?
1bad95
Mine also was doing exact symptoms. Was going to do the spring mod on the cable but glad I didn't and just pulled the trans as my tob was in 3 pieces
Also replaced the clutch fork and pivot ball at same time.
Sent from my XT1080 using Tapatalk
Mustanger
Southern Oregon
yeah you will know if it's worse case like 1bad's...because the spring won't change anything....but it is less $10 bucks at Home Depot to find out! and it will still help you in the future after you replace the broken clutch bearings etc..I like to start cheap & small at first if I am hunting for the fix.
