I had my exhaust all redone and while they had the mid pipe out i had the shop service my tranny and replace the filter/seal/fluids in hopes that would fix my leak. Seems to be leaking still not sure if the pan bolts need to be tightened down again or not. It seemed to leak alot more when i jacked it up from the front. Also like 4 months ago i replaced the bearing where the drive line connects to the tranny where it was leaking a little bit and thats no longer leaking.. Any ideas? Thanks! And here are some photos i took of it today. Did not feel like crawling all the way under, may call a friend with a lift and look into it more.
Check your pan bolts and make sure they are torqued. Sometimes with a new gasket you have to let it heat cycle a couple times and retorque it. You really need to slide under there and find the highest point that's wet and that'll probably point toward the origin of the leak.
