Stock engine plus Turbonater owns all previously mentioned combos!
Lee12609 said:McCloud said:I made 316/301 with the Trick Flow 44cc heads, Trick Flow intake, 75mm TB, CMS Stg III turbo cams, and BBK shorty headers on a 9.0:1 323 cu. in shortblock through a stalled automatic. I think it would've been possible for me to make 350rwhp had I run higher compression, used some large duration high lift NA cams, and used my old longtubes.
thats over 350 with a manual trans, but how high was you revving to get them numbers???
DropTopPony said:
army35m said:what the crap dude those stupid little things you stick in the intake dont work! Thats as about a good idea as an electric supercharger or electric turbo, they do more harm than good.
army35m said:I just saw you have almost 300hp at the wheel, how much different does it feel than stock and are you satisfied with it?
Duff Daddy said:justin you do kn0ow their test mule made 385 last year with their heads and stage 2 cams with stock upper and t/b right? ....
navarro98gt said:army35m said:I just saw you have almost 300hp at the wheel, how much different does it feel than stock and are you satisfied with it?
Feels way different then stock. Ran a 15.1 stock and 12.72 as it sits now.... night and day difference.
No I'm not satisfied, and I don't think I'll ever be satisfied.
army35m said:Ok so what if I go with a PI swap and cams and the bolt ons such as headers, ud pulleys, CAI intake, etc and a good tune then could I hit 300rwhp? I want something that is easily an everyday driver, yet is fun to take out and hit those back curvy roads.
Lee12609 said:start with the basics, gears, intake, exhaust.... those parts will interchange no matter what build you do so just start there.
justinschmidt1 said:.Lee12609 said:start with the basics, gears, intake, exhaust.... those parts will interchange no matter what build you do so just start there.
thats not really true at all...your intake will be worthless if he gets a blower, gears should be determined by setup.
If he stays n/a and goes with that high revving trickflow stuff he should go with some 4.10s-4.30s, with a blower I would say to stay with 3.73s
