trickflow intake in new summit catalog
svtboy
PG 286 in the new summit catalog has the 2v trickflow intake manifold for sale. Price $799 for bare, silver, or black looks like its time for somebody to buy it and test it out.
MeanGrn Gt
ill test it.... but someone would have to buy me a car to test it with cuz i dont think it would fit the 5.0 too well ;D
svtboy
scarface said:
dang, I thought that thing was going to be under 500 bux?
You cant even buy a 5.0 intake under $500. most are around 500-600 range new.
Fets
Yea I seen it in there too. Awaiting someone to test it out
Pennywise2
Yep it is $800.00 plus shipping.
The new Trickflow intake manifold only gives 10-20 rwhp from
what I have heard what a complete ripoff I would never buy one.
You could get a Nitrous Express kit with all the goodies for the price
of that intake.
svtboy
of that intake.
10-20 rwhp is good for a intake... $800 is a little much for an intake, $500-600 would be more reasonable.
smasher41
is this for NPI or PI heads?
if non PI maybe ill take the fall for us all, My Boss is setting up an account with Summit soon anyways! :)
smasher41
ahh darn, info i found on moddedmustangs:
Trick Flow 4.6L 2V Track Heat Intake Manifold
General Specifications
Made in the U.S.A
Materialâ€â€A319 Aluminum alloy.
Designed for 1999-2004 4.6L Mustang GT ( modifications required for 1996-’98 models ).
Fits 1999-2004 Power Improvement head ports.
75mm Throttle Body Inlet.
Symmetrical high velocity intake port design.
3-PC design.
Accepts, but does not require aftermarket high-flow fuel rails.
2001 Special Edition Mustang performance when used on unmodified Mustang GT without costly additional components.
Increased performance potential over similar more expensive manifolds.
RPM Range: 1500-6500 when used with un-ported cylinder heads.
RPM Range: 1500-7200 when used with aftermarket or ported cylinder heads.
Same overall height as stock plastic lower intake manifold/ upper plenum assembly to minimize hood clearance issues.
Complete kit with detailed installation instructions for 1999-2004 4.6L Mustang GT.
Part Number: TFS-51800002 ( Silver metalic powder coated finish)
Part Number: TFS-518B0002 ( Natural finish )
Part Number: TFS-51811002 ( Black powder coated finish )
Estimated M.S.R.P ( < or = ) $ 799.00 ( Available Early Spring 2007 )
svtboy
It can be used used on non pi heads aswell. Just like putting pi intakes on non pi heads. RTV or adapter plates.
Outlaw97GT
10-20 more hp over a PI intake?
So for 800.00 for an intake and 100.00 for PI cams. Thats 900.00 and the PI kits are 1350.00, You could get 5-10 hp over a PI swap and save 350.00 and not raise your compression.
Just and idea......Discuss
ck5.0
Isn't the trick flow for 450 the only one under 500? I guess if you are buying an upper and lower there isn't much for under $500.
DropTopPony
South Jersey
It still hasn't been released yet...still just another intake coming soon until its actually done and it has been pushed back again to late spring.
jpajkos
Well I would hope its at least a 20 horsepower gain. 10 to the wheels isn't shit for 800 bucks.
Pennywise2
It is just a new intake coming out.The Trickflow intake has never been tested
and all the power gains are all accusations.From what it says on the intakes bio
this intake raises the powerband higher in the rpm's.In my opnion it will probably produce
more power than a standard PI intake.The price is outrageous though.
Cregar24
