ryclef331 said:http://www.allfordmustangs.com//Detailed/50.shtml
You ain't gotta use steel for the straight piece. I used PVC Pipe for the whole setup. They say you need a "MAF Adapter." I ended up figuring out a way to chop up the stock air box to get a cone filter on the end. It wasn't pretty but I got it.
Also when you're in there working with the MAF...rip out the screen. MAKE SURE you get all the lil strands.
Yep, a home made cai is cheaper and does the same thing as the aftermarket ones. I have one! And STAY away from a steel pipe, they heat up so bad that they can cause problems with your IAC (heat soak, I think it's called). It basically heats up a lot that it's inducting nothing but HOT air and since the tube is hot, the iac can soak and get out of whack. It isn't the first time that someone claims that pullies dropped their time by several tenths. And regarding your tranny, when my car was auto, I found it to run BEST when left in D. It shifted firmer and pulled harder.
