Can you run turbo cams on a N/A engine until you get the turbo kit you desire? or is it just better to run a normal NA cam and swap them out when you do a turbo kit? Nathanael
Will you make more usable power in the range you want? Probably not. The benefit with turbo cams is they are somewhat tame. They have the added lift and duration but the LSA is usually close to stock or even more tame. The tune will be a bigger factor.
Would it be better to buy a NA cam suited for head and turbo it? or just buy turbo cams for it reguardless...This is going to stock bottom end low boost...
Yup, I was looking a MHS for cylinder head & cam combo. I will be happy with 400rwhp for now until I can afford a built bottom end. I am trying to take baby steps since im not rich lol.
Low boost you will want you can and head selection to be correct Sent from my SPH-L720 using Tapatalk
N/A....Tfs heads, tfs cams, professional products aluminum intake, long tubes, all tuned out equates to 400rwhp(actually 408rwhp peak) In other word....you can do it!
