Turbo kits for 2V
Rjnelson222
Hi everyone, I currently have a 98 GT that I am planning on building, currently stock 2V Windsor block and I am looking for turbo kit recommendations, I know I will have to change K member and other frame pieces.
I have thought about one of the on3performance kits
badass98svt
How much power are you looking to make?
How much money ya got?
Are you doing the work yourself?
R
Rjnelson222
Yea doing the work myself, honestly trying to learn about turboing the 2V, not trying to break the bank super hard, maybe in the range of 2-4k at most for the kit itself, anybody got any recommendations? And for power, whatever a stock engine can put out
R
Rjnelson222
Meant stock internals if wasn’t clear
Snorky
The on3 kits are okay. I would definitely opt for the ball bearing turbo and maybe the billet wheel ( loved my 67mm bbb) and rock the on3 restrictor plate. Change the turbo drain and oil filter relocation kit to a 10 AN line setup. Use an sct ba5000 or equivalent slot style MAF and use an 05-09 MAF pig tail. Have on3 weld on the maf flange for you, saves the headache of having to find a flange, cut the tube and find someone with an AC welder. The headers I would check before installing and kiss them on a belt sander if they are not flat.. both flange and V band. The v band clamps are kinda crappy from on3. I would get some 47-60 lb injectors and a large pump and give it a go. The down pipe back exhaust is another discussion
white95
Apex Junky
Prairieville, LA
Precision 6266 would be an even better choice!
badass98svt
At 2-$4k you dont have many options
I'd just go with an On3 kit and upgrade the important bits
garrittpwl
Indiana
I've been building/modifying a 4.6 on3 kit for my 5.4 and honestly I've been impressed with the quality for them being a "cheaper" kit. I would definitely recommend.
jarthur1995
