They are A/C related. As to what they do I cannot say as my A/C knowledge isn’t the greatest. To clean them up you would have to drain the A/C system and disconnect that line. It’s a long one though. More trouble than it’s worth in my opinion if you are doing it yourself.What are these two canisters? Radiator & heater related? And what can be done to pretty them up? They’re just fugly!View attachment 46175
I have no straight answer for that, but if I were to guess, it is an anti rust coating, as if that line were to rust through and make pinholes then the refrigerant would leak into the atmosphere. Big no no.I wonder what that crap (coating?) is on them? And can it be removed/cleaned off? Or is it necessary ie, has a reason for being on there?
I believe they are cast into the line, so they are not a separate piece that is attached. This is what I remember when I was messing around with my A/C delete.Thx, John. What kind of filters are they? And why won’t I be able to access them (confused)?
Not sandpaper, 0000 steel wool. I did a bit already and it took off the top layer fairly easily. Hard parts will be getting all of it (tight reach) then applying paint or putting some kind of coating on it.I'd start with a damp rag and barkeepers' friend before trying sandpaper.
Nice snailNew lines are nice and shiny. Doubt paint would adhere View attachment 46191
