Anybody know if the harness for the under-hood fuse/relay panel is the same between 99/00 and 01-04? Looks like in my attempt to remove the injector harness from my 2000 GT, the main buss-lug on the fuse panel twisted and messed up the entire fuse panel on the bottom... NO clue why that connection was so damn tough to break loose... I'm looking for a replacement, but not sure if an 01+ would work on my car or not. I'm assuming that I'd need one with ABS & TC regardless of the year though..
I just had to go through this. I cut the box off of a 2004 v6 and rewired my harness into the new box. It is not hard to do. Just take pictures of the location of the fuses, and then with the fuses removed. Then the backside of the fuse holder is numbered, I wrote down what number was associated with which wire color and swapped them. As far as I can tell all power distribution boxes are the same on the sn95.
