as for the tech, I can't help but notice how much more convincing you are when you're not personally bashing another member... you've gone from " some troll" to "I hope he tells us more"......
so, was that video filmed with oem or poly bushings?
do you have any videos with the UHMW bushings?
That particular video was shot by a Full Tilt Boogie Racing customer that was going to do before and after videos for us. This video was shot with the OEM rubber bushings in the lower control arm. Similar deflection of the control arm would result with a poly bushings. This customer was also going to do an 'after' video for us as well but ran into some personal issues and ended up having to sell his car without installing the Delrin control arm bushings. We hope to some day shoot a video with the Delrin bushings in another car.
Control arm deflection is the axis of evil for drag racers, road racers and anyone that likes to corner carve with their car whether it be canyon roads or freeway cloverleaf on and off ramps.
SRA or IRS will have the same effect ...
CMC cars, even with a mere 260hp, are having issues with tearing up the factory torque boxes. Even with the reinforcement kits. There is a petition to allow the Mustang chassis the Wildrides Battle Box, but all the adjustability will probably keep it out of the rulebook. The factory rubber movement is not ideal in a race car, but there has to be a balance.
The problem is that when you add stiffer bushings to any suspension piece, its sister pieces/bushings end up taking more of the deflection. Eventually the damage will start to tear up pick up points, specially if you have no give in the suspension, like delrin or aluminum.
Unlike the thin layered sheet metal in a torque box, the IRS subframe is a significantly stronger assembly. You will NOT see control arm mounting point issues on an IRS subframe that you see in a chassis torque box for an SRA.
