01yellercobra
- Joined
- Feb 23, 2018
- Messages
- 628
- Reaction score
- 193
That's not the word I was thinking of.this should be fun
I finally have all my parts I need in order to swap the shafts and install the much stronger Gforce units. . In addition to the G force Shafts, I'm going to re seal the diff. Parts list is as follows: new Maximum Motorsports IRS cross axis joints, G force outlaw axles, plus sway bay end links From Maximum Motorsports as well, Red Line synthetic gear oil, Aeroquip AN fittings so I can install an oil cooler later on down the road and POR 15 to refinish the IRS subframe.
Notice the new Ford fuel filter: might as well replace it while the IRS is out.
Key point here is that I went the leader in Mustang Suspension: Maximum Motorsports. Fun FACT: Only Maximum Motorsports has set lap records and race wins with their IRS parts and the quality of the MM suspension parts is second to none so once again,
MM was the only option for upgrading the IRS cross axis joints and sway bar end links.
That is a nice chunk of parts.
Your info is wrong here as there are other companies that also offer cross axis joints and sway bar end links. Unless that was just your personal opinion.
I only run the best parts for the IRS, so that means using Maximum Motorsports parts. Additionally, I chose the best axle shafts available: G Force engineering.
G force is the axle supplier for Ford Performance and here is Ford talking about these shafts that I’m going to install in my Mustang
That video has nothing to do with G Force or a mustang cobra irs. That was all about the ford performance half shafts for the 2015 mustang.
Try again.....
You just made up that untrue statement.That video has nothing to do with G Force or a mustang cobra irs. That was all about the ford performance half shafts for the 2015 mustang.
Try again.....
Funny. You say I made an untrue statement about the video you posted. Did you even watch the video?You just made up that untrue statement.
Here is proof to back up that G force makes the axles for Ford Performance:
https://gforce1320.com/gforce-to-manufacture-s550-mustang-axle-shafts-for-ford-performance/
Lwarrior you da man!! I don’t care what white says!!!! [emoji1787]
I don’t care what he says either.
Unless me saying that upsets him, then I care.
The news link I posted directly from G Force is more than enough information to prove my point that G Force is a supplier to Ford Performance.Holy hell........he almost linked proof to something.
Now where’s an article or declaration from ford stating this?!?!?
