URGENT! Need a PI intake, will this one do?
dwcopple
This one is aftermarket but looks more like the PI Ford performance than the Dorman. I need one ASAP for my car that just had the heads done.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
That should work. It has the inserts for the fuel rails and the aluminum crossover. The only other thing to check is the gasket surface. Make sure it uses stock style gaskets and not the o-rings like dorman. Either way, it should be ok to get you going.
96blak54
In the shop
Definitely use the felpro intake gaskets. All other brands are not to spec thickness and could cause a leak. I got a write up somewhere around here. Ill find it and link you
