Vacuum question
DarkknightGT
I have been chasing vacuum lines GALORE trying to find this slight misfire and low idle upon first start up. Ive adjusted the idle and done a reset so many times its not even funny. Ive found some older stuff regarding deletion of vacuum lines but theyre all older threads and most comments are smarty pants responses. I also want to delete egr as well. I wanna know what goes into that as well. Also dont have emissions where im at so thats not an issue, I also wanna know if I do delete this stuff, is the car gonna run if I delete it and cap the unnecessary vacuum off?
Terrorist 5.0
Well typically a vacuum leak results in a higher idle that fluctuates. not a lower one. Smoke test the car. That will find your leak if there is one. Check for codes as well. Always check for codes.
EGR deletes are not really possible on these without a tune. You will get a check engine light. No simulator plugs for the SN’s that work, that’s a primitive Foxbody thing. If it is working fine, just leave it. It helps out gas mileage. I had mine blocked off with a piece of soda can because the valve was stuck open and the replacement one didn’t fit.
DarkknightGT
DarkknightGT
For some reason the cel hasn't come on in a bit but I would get a 10, 111, 157, 211, 212, 327, and 332. I just replaced the distributor, ignition coil, spark plugs and wires about a year ago, so I dont think its the pip sensor like everyone said it was. 212 was what I was concerned about before, so I replaced it all and it idles but the needle bounces slightly and it idles semi low on cold starts, like 450 to 500 rpm range. Im honestly at a loss at this point with this thing.
tvsn95
first what year? if its a 94 style it has NO feed back to the EGR as far as flow detection goes. you can just cap the vacuum line. problems come from the valve leaking. it is best to remove and plug or cap the manifold and of course the exhausts. seems like I originally built a block plate, and since have tapped and plugged this in the manifold. the exhausts was welded shut at the screwed connection and reinstalled to seal.
DarkknightGT
DarkknightGT
Its a 95 5.0, so is it different?
95opal
With the engine cold, start the car with the iac unplugged adjust the idle stop screw on TB until it idles at about 1000rpm. Shut it down plug the iac back in and see where shes at. The only code i see you didnt address was the 157 MAF.
tvsn95
For what its worth, Pull the ECU and look inside, there are 2 capacitors that fail. ( they may even have green corrosion) they are cheap and not hard to do, get the polarity right.
DarkknightGT
DarkknightGT
I also replaced that as well. But that doesn't sound like a bad idea! I will do that and let you know. I'm also gonna pull it and clean it as well so even more of a plus!!
DarkknightGT
DarkknightGT
I'm fearing that tbh. When I got the car apparently some wires that went to the distributor were bare and arching against the block, causing the distributor to short out and it actually melted the CCRM. It was a mess!! Im also thinking it could have shorted out my tfi module as well so I may replace that
tvsn95
just as another note, I personally went through a terrible experience with EMP interference from the alt and the ignition. It got worse over time and was VERY confusing. cost me a fortune in head gaskets and parts.
The short solution turned out to be a new set of FR plug wires and Faraday tape wrapping of the harness. I cant understate what a diff this made.
So yeah, the wiring needs to be good BUT spend the time to Faraday wrap the wires and save yourself the other crazy problems that just don't make much sense . the wrap is cheap.
DarkknightGT
DarkknightGT
That's a good idea actually, I'll look into that stuff actually!
cobrajeff96
Germany
Just make sure you either use some type of Cuban. Stangs don't like low Q cigars, the problem will worsen if you go cheap.
DarkknightGT
DarkknightGT
What about a particular green substance? I heard that stuff does really well but it can cause a bit of stumbling i guess
cobrajeff96
Germany
Probably nothing much'll happen except for a brief period of higher fuel consumption afterward. Maybe the headlamps might fog up a bit.
mr404boi
