I had the same problem.. my hydroponic fluid in my convertible top motor was very low.
I had the same problem.. my hydroponic fluid in my convertible top motor was very low. (i have a very small leak) the easiest way to get to the motor is to remove the back seat. you can also get to it from the trunk. The real PITA is filling it up. It takes automatic trans fluid. but the plug for the drain hole is small. I used a syringe to fill mine back up it took forever though
Thanks for the tip I'll pick up some Tomm and try it.
If you care about your car, Dont just add fluid...chances are its leaking the fluid out behind the rear panels. Pull them out and see whats going on before adding fluid or you're car is gonna smell like a transmission shop. Chances are one of the lines split or one of the lift cylinders is leaking.
Good point lolIf you care about your car, Dont just add fluid...chances are its leaking the fluid out behind the rear panels. Pull them out and see whats going on before adding fluid or you're car is gonna smell like a transmission shop. Chances are one of the lines split or one of the lift cylinders is leaking.
I tried but couldn't figure out how to because of styling bar. How do you remove the panels if u have a styling bar
* Sent from tapatalk while sitting on the toilet at work*
