ElrodKTPQ_89
So the other day was nice and I decided I'd get the car out and wash it. After I cleaned it up I drove about a mile down the road to blow the water off. Everything was running perfect. Came back home and put my new headlights in and decided to go down the road one more time before I parked it back in the shop. I drove about half a mile down the road, and when I went to turn into a driveway to turn around the car just randomly died. I fired it right back up and turned around and headed back home. When I turned on my road the car died again, and this time it took several tries to get it to fire and run for more than a second or two. I drove about 100 yards down the street and when I turned into my house it died again. This time it took about 3-4 minutes to get it to fire up and run, and I wound up having to keep it idled up and put it in drive to get in around in my shop. About two days later I fired it up and it ran absolutely fine like nothing had ever been wrong...for about two minutes then it just died all of a sudden. When I tried to fire it back up it wouldn't do anything but click, and acted like it wasn't getting a good connection at the battery...if you moved the cables a little bit, the fan would come on for a sec. I bought a new battery yesterday finally and when I tried to crank it I couldn't get it to fire up and run. My buddy/ford know-it-all came by today to check it out. He got it to fire up and it ran ok for about a minute, then started idling terribly, like it was flooding. We tried unplugging various sensors, taking vacuum lines loose, etc. Nothing seemed to make a difference. The only thing he thought it may be was the fuel pressure regulator. Almost everything under the hood is brand new, the only sensors I haven't replaced are the TPS and IAC. Only mods to the car are smog pump delete and catless exhaust, Fox headers with no EGR bung; The EGR valve is on the intake and the solenoid is plugged in, I just have the tube capped off. Other than that the motor is all stock.
If anyone has any idea what could be causing the madness please lend me some info!
-Elrod
-Elrod
