hey fellers, i just sent vt engines tech dept a e-mail...any thoughts, tips, ideas? here it is:
hello, if i get long winded, i apologize...but i like what i see on your site and have heard great things about your products. i have some questions before i "delve in" and want to get everything straight. i've got a '96 mustang GT(S) {came w/ manual windows/locks, no fog lts, no wing, cassette/no cd, and 3.27 gears instead of 3.08s). car has 94,000 miles w/ stock: (bottom end, heads, npi intake, 19# injectors, computer). currently i'm running a 8# powerdyne s/c, 190lph fuel pump, stock maf sensor, accufab plenum/75mm TB, 3.73 frpp gears, fms aluminum driveshaft, centerforce dual friction clutch, diablosport "maf"ia maf spoofer, bassani catalytic x-pipe, flowmaster 2 chamber cat-back, ngk stock heat range spark plugs and a pro 5.0 short throw shifter. i have bassani optimum length headers and 30# frpp injectors still in the box to install yet. i currently have the car tore down for a pi intake and pi cam install. i sent my s/c back to powerdyne for 60K mile servicing. while it's away, i got to thinking. i'm looking at your vt stage 2 romeo heads, vt stage 2 blower cams, arp head bolts, ? type head gaskets, ? type exhaust gaskets. questions are: will these heads raise my compression ratio? (i am leary due to the s/c, and there is no more 100 octane available out here in vegas, all we got is 91). what other parts would i need for the swap? do you all know of any good dyno tune shops in las vegas, nevada to do a dyno tune for me after all is said and done? will the comp cams valve springs in the stage 2 vt heads satisfy the required valve spring upgrade of the vt stage 2 blower cams? will these heads/cams work w/ the stock pcm? what is the operating rpm range of these cams? any piston-to-valve clearance issues? i am not looking to make a "drag only" car, just looking to have some fun. what do you think of my set-up/plans? If i were to order the above parts and whatever you recommend as needed in addition, could i catch a deal (as an sn-95 forums member?) would you accept 2 forms of payment (debit and credit card)? please let me know, i am eager to get this car going again, the right way. love your site and items! :blah2: :blah2: :blah2: :blah2: :blah2:
