Reading off the efi "microsquirt" website it says: "the MAF sensor is not used, making microsquirt excellent for boosted applications.
So does this mean using microsquirt, I won't need a MAF sensor calibrated to 36 lbs? And can run my stock MAF meter with 36lb injectors?
The MAF sensor is deleted.
You won't need a MAF sensor.
The Microsquirt uses a 3-Bar MAP sensor and has a vacuum port built in to the ECU itself which draws vacuum directly from the intake manifold.
You use a software like Tuner Studios to calibrate the Microsquirt to your injector size, negating the necessity for a MAF.
Quite frankly, you're on the edge of needing larger injectors if you go with the 36's and want to hit 350-400HP with Forced Induction. You'll be pushing the duty cycle of those injectors to their maximum and here's the math to prove it. These figures represent HP at flywheel, not HP at the wheels. Divide the injector flow rating by .5 and multiply the results by the number of injectors. This uses a 100% duty cycle. This would be for a naturally aspirated engine.
36 / .5 = 72
72 x 8 = 576 HP
A safer duty cycle is around 85%, so lets multiply the result by .85:
576 x .85 = 490HP
If we calculate a 15% drivetrain loss (if you're running a manual transmission):
15% of 490 = 73.5
Minus 15% drivetrain loss:
490 - 73.5 = 416.5 HP
So as you can see, if you'd like to safely reach 400 wheel HP with Forced Induction, it would be wise to look into selecting a larger injector. Since you're looking into a standalone ECU, I'd pull the trigger on some 60lb or 80lb Siemens Deka injectors. You have the computer to tune them with so it's a good investment. If you step up in cylinder head or turbo size you'll already be set with the appropriate injectors. FWIW I run the Siemens Deka 60's on my turbo SBF and that one is a stock longblock. You'll easily make 400+ with the stock engine, all it needs is fuel delivery and tuning. You're on the right track with the Megasquirt.
