Last Thursday morning I had the hood open on my 94 GT, trying to find the pcv valve on the back of the engine. I was standing on the passenger side with my left arm and head in the vicinity of the firewall when my right elbow hit the hood rod and the hood came down.....hard. I got my head and right arm out of the way but my left arm was a little slower and the hood slammed about 3 inches from my wrist.....and locked down. The safety catch behind the grill caught and held the hood tight on my wrist. It hurt so bad I figured it broke my arm and as hard as I could pull my arm would not budge. I tried to stretch to get to the release handle but no luck. I got my right hand fingers under the hood and picked up as hard as I could while pulling on my left and no luck. I then tried to pull up with my right and pick up with my tip toes and all I did was pull a muscle in my leg.
I was at home by myself and my neighbor's house was about 100 feet away but they were both at work. No one lives across the street and I was starting to panic. I tried again to pick the hood up with my right hand, knowing it was going to crease the hoods edge if I did but at this point I didn't care. I could not pick it up. I tried swiveling my hand some and placing my right hand on my left arm pulling it toward the front of the car. It moved about a quarter of an inch toward the front but was tearing meat in the process. I kept doing this over and over, finally getting an inch or two toward the grill and it was getting looser on my arm. I finally got it out. It was mangle up pretty bad and bleeding ( I take blood thinner), but I was free. I went in the house and washed it and decided it wasn't broke, wrapped it up and all was ok.
The next day I popped the inside hood latch, then picked up on the front of the hood without popping the safety latch. There was only about half an inch opening where my arm was. I guess the left side pivoted up at the latch while the driver's side went down to make room for my arm. The hood wasn't damaged, just my arm and my pulled leg muscle.
