Maximum95
I would suspect the switch first if it were both lights but with it only being one it is unlikely.
I should have said check the headlight switch in regards to the foglights not working.
Fog lights are on a separate toggle switch located on the center console.I should have said check the headlight switch in regards to the foglights not working.
aah… I (obviously) did not know that but thank you for the info. So do I need to pull the dash bezel to inspect the headlight switch?I am aware. I have the same switch. The foglight switch power is supplied through the main headlight switch.
that would not be safe at all. Get one of those lights you strap on your head so you keep your hands free.Just buy a flashlight aim ot out the window
Just kidding
Yes, I have a voltmeter. I don’t know how to use it to test the wires on the headlight bulbs pigtail. It has 3 wires: green, black and red. Don’t know what to set voltmeter at? Touch red needle to each wire separately with black needle (where)?that would not be safe at all. Get one of those lights you strap on your head so you keep your hands free.
In all seriousness this one confuses me with the one headlight dimmer. Do you have a volt meter you can stick on that light to see what the voltage is?
Right, just as @ttocs said, DCV. Unplug the headlight bulb and test to see if you're getting voltage at the connector.
set the meter one click to the right to DCV. Turn the lights on and poke the black lead to the black wire and the red lead to I think the green but it might be red. You do not need to worry about being shocked or messing anything up as long as you do not short the two leads together.
