What are these connection in front of the pcm harness?
Cobra82
I need to know what the wiring is for these. I removed the stock computer and harness to do the holley terminator x kit on my 95 mustang and I know some of these wiring goes to cluster and transmission. I have a 5speed. I'd like to cut out all the wires I don't need anymore off the stock harness and ccrm so I could still use dash for like speed and rpm. I cant find anything for a wiring diagram for these plugs
I see a series of pink wires in one of the harnesses. The lock wires are pink/yellow and pink/green.
Cobra82
Well I hope not. Because the other end of the harness was connected to the pcm plug that is all gone and replaced with the terminator system. The other end of the plugs went to the engine harness to the 42 pin bulk head plug
Michael Plummer
Brockton, MA
I would wait until you get your car running with your new Engine Management System before cutting out any wiring. Or you can always pick up a 1994/1995 Ford Mustang Electrical and Vacuum Troubleshooting Manual from eBay to assist you in identifying your wiring and connectors.
Good luck
Michael Plummer
it would be a good idea to get a manual since you will be knees deep in wiring. Mine is unfortunately packed up in a way I can't get to it at the moment or I would be in it to help. They have pics of every wire harness in the car and what it is. I got it off of ebay years ago it just has an orange cover on it.
reedj304
