RAU03MACH
today a little later i will add the coolant to the engine and proceed to start up and test ,
check everything over for leaks and whatever happens ,
That's an awesome motor in there. Is that the same one you had the Kenny Bell on?today a little later i will add the coolant to the engine and proceed to start up and test ,
no this engine i built and swapped it out of my 98 gt my 98 2 valve was getting tired anyways , so i had parts to do the swapThat's an awesome motor in there. Is that the same one you had the Kenny Bell on?
Very cool. Habe any pcitures of the setup or parts?What I'm currently installing on my 98 coupe drag car. The rear is from a 2003 GT. Has 35 spline axles, c clip eliminator and spool it's a strange system. Well with the only brake upgrade that will easily fit is an aerospace components kit, but now I have to redesign the lines to SAE. The factory fitting are metric. The rotor and caliper install was the easy part. Kit comes up with everything including caliper mounting brackets that fit the strange C clip eliminator blocks. This kit fits within a 15" wheel with about 1/4" clearance
It does seem a little noisy but doesn’t really sound concerning. Any idea where the noise is from? Lash adjusters?The top end a little noisy
It is running smooth no missing
Oil psi is good
Not overheating
Just smooth with a little noise
