- Joined
- May 31, 2019
- Messages
- 925
- Reaction score
- 1,140
A quick look and it looks like the RF is running dually's.Quick garage Pic! Wife likes the black more...... View attachment 43898
I should clarify a few things: my system has been checked, several times, and as lately as a year ago when all this started up again. I pride myself on the work I do and have done others setup the same way, both Dual Sync and CNP's without incidents...yet. I have gone as far as checking each wire to the ECU just being anal and although Holley or anyone else doesn't know what we do, I can honestly say the system is tight! The engine/chassis/battery is over the top analy wired. This is the first thing Holley or anybody else says, so I'm always a step or two ahead of them.just because the wiring has been there for 11 yrs does not mean that some corrosion could have snuck in somewhere, creating some resistance and when it is not bad enough to kill power completely it can make electronics very very unhappy. If you have not checked all your grounds you should and by check I mean remove, clean both surfaces and then retighten. It also would not be a bad idea to unplug any harnesses you can reach and look inside of them to ensure that some water didn't make it way in and cause problems.
I have been running my stock dist with my HP but I have a dual sync I found used a while back. I have just been waiting for the stocker to crap out to do the swap and it has not given me any problems.
Dang man, hope you have a ladder, chain hoist and/or sky-hook to get that done. Either that or some good helpers while you sip your specialty.Gave it a bath
Honestly the bronco is a breeze to clean. The truck on the other hand definitely hurts the knees to get up in the bed. That is really the only thing I miss about the newer f450 I had. The sweet ass tailgate step!!!!!Dang man, hope you have a ladder, chain hoist and/or sky-hook to get that done. Either that or some good helpers while you sip your specialty.![]()
Replaced the headlights with cobra-style ones.
It was a good bit harder than expected because I had to do drill two holes for the EUparking lights. Also it turned out that the new plastic "nuts" that fix the adjustment screws are a tighter fit than the stock ones. After they popped into place, I couldn't remove them again with pliers or the 12mm box wrench. I had to cut them down and use the old stock ones.
Any idea where I could buy such "nuts" that are like the stock ones?
Good to know and thanks for the follow up, Jeff… which I’m glad I waited for. I’m still running 50/50 with Water Wetter and aluminum radiator and it’s been working as it should. Auto meter gauge stays at 190* under normal driving and fan kicks on when it gets in the ~210* range (+/-)Ditched the Evan's Waterless Coolant and went back to the tried and true 50/50 mix with some Water Wetter. I tried the Evans for about two weeks and was not getting a good feeling about it at all. Right away, I noticed the coolant fan would activate a good 5 to 10 degrees hotter than normal. Didn't freak out but I paid attention.
A couple of recent days were around 80 - 85 F ambient (warm but not hot like Florida is where I'm from). And fuck I noticed the coolant fan was coming on despite going about 100mph down the autobahn, so there was plenty of air moving across the radiator. It stayed on for a few minutes and I'm sure glad I made an LED indicator circuit to tell me whenever the radiator fan activates.
It would take nearly twice as long for the system to shed away heat with the Evans coolant inside, as indicated by the in-cabin fan activation LED. I might've just been overly anxious but I thought I noticed a slight loss of power, like the ECU was pulling away timing out of safety.
Bad experiment. FAFO.
I may have something in my baggie of bits & pieces leftover from previous headlight headaches! So can you post a picture of what you need, where it’s located, etc? FWIW, I h8 doing the headlights! For me, it’s not so much the R&R, it’s the adjusting. I even took it in the shorts and bought that ratcheting headlight adjustment tool from LMR, which didn’t do squat to adjust the beam.Replaced the headlights with cobra-style ones.
Good on ya, Weendoggy! I’m sure your friend was grateful for your time, help and know-how. I’ve been in his shoes countless times. One of the best parts of getting involved in a hobby is the learning and camaraderie, IMO.Nothing to my cars today, but helped (I did most the work) a friend install a 1 1/2" drop Koni setup in his newly acquired S197 2012 Mustang. He used BMR stuff and included an adjustable rear panhard bar. Took me (us) about 5hrs to do front and rear. Struts in front were nerve-racking when I thought my compressor wouldn't do it, but had just enough threads to release the old springs. New install was a snap.
Are you talking about those pronged bullet nuts that need to be pinched to remove the lights?
