Daryl
Somis, CA
Put on a new EGR… but having a bit of a struggle threading the 1” nut back on.
Update: ended up just cleaning the old EGR valve and reusing it as the replacement didn’t thread on (male end too narrow). Old one went right back on no problem.
weendoggy
When I did my 4.6, it's much easier to get it started a thread or so, then bolt the valve on, then tighten the nut(s). If you can loosen the other end, even better. Make sure to use antisieze!
Daryl
Somis, CA
Yep, that’s the procedure I’m going to do today. Starting from scratch (removed entirely); then start threading the 1”nut (with anti-seize); then the gasket on the studs; then the washers and nuts in the studs; then alternate tightening each 3 up so it aligns itself to where it’s going to live!
Of course reattach the connection and hose line.
SHDOPNY
Socal
I finally finished my front coilovers and power steering job. So it's finally off jack stands. Also installed a used cold air intake but now my idle is really bad. It continues.
Daryl
Somis, CA
I could NOT get the nut to start threading. Removed it and measured it compared to the original that came out and the replacement (Wells brand) is narrower, which explains why it just kept spinning (yes, I tried it in both directions!) and not biting/grabbing a thread. Sending it back and shopping for a MotorCraft 1st choice or Dorman 2nd choice if Motorcraft not available.
Why are you changing the EGR valve?
Today I will be parking the car, turning the defrost on to high, the rear window defroster on and the seat heaters in preparation for the snow/ice/nothing that might happen this tomorrow so it is all ready to come one when I remote start it. They started off on wed saying 1-4", thurs they said it could be more and now today they are saying it could be up to 15". Because of the river valley we live in it makes it hard for them to say what will happen so we could get flurries/nothing, or 15" with ice snapping all the trees like last year.....
Are you in the line of fire blak?
joemomma
They can't figure out what we're going to get either. Started out as double-digit snow totals, now we're in for "several inches" of snow and sleet with some ice (freezing rain) thrown in for fun. We likely won't know until it's happening one way or the other.
I swear almost any weather map you will find there is line that goes right next to the very tip of indiana where i am at that falls from good to bad very quickly. The river valley does strange things to the weather I have seen where on radar it looks like moses parting the red sea as a storm will split and go around us, other times it sucks the storm in and will not let it go so easy.
I got spoiled the 10 yrs I was in phoenix. I never knew what the weather channel was on my cable system, never needed it....
badass98svt
My area is saying anywhere from 12-24".
Im 20 minutes north of Boston
mattn03
