What exactly is missing in my Supercharger Kit?
SonicStang
I know there are missing a couple parts to make it complete, but can you tell me which ones exactly? Check out the picture I took.
I am guessing the following is missing:
- Fitting for Oil pan (for oil drain hose)
- Fitting for Oil feed hose
- 3-1/2" Flex Hose
- Short hose from Bypass Valve to Plastic Elbow
- Radiator Hose Extension
- Passenger Coil Relocation Bracket
- XCal (I don't want to use the FMU)
What else? Anyone having an idea where to order this crap?
ju015dd
tallahassee, fl
i have the oil drain hose assy which comes with the fitting you will need. i paid 28 bucks from vortech you can get it for 20 shipped.
ripper
I dont see a fuel pump. You need a 255gph along with your in tank. You also need to change your plugs DO NOT use platinum plugs. I use autolite 103's gaped @ .035
Heres what happens to platinum plugs and s/c lol
[attachment deleted by admin]
SonicStang
Fuel pump is on the lower left, a walbro 255. I recently bought a AMS power pipe so what's still missing is the coil bracket and the Xcal2 I believe. I am already running NGK iridium plugs.
Tornbetween2
So where are you going to get these parts?
I Would like to see what that coil bracket looks like because i need one also. i think vortech wanted like $57. i also need a radiator hose extension.
So Let me know where the cheapest place to get these things or if someone wants to show pictures of these things so i can make them. that would be great!
SonicStang
I am looking to create that bracket by myself. Once I have made a template I can scan and send it to you.
As for the radiator hose extension I forgot about this part. I will try www.superchargersonline.com maybe they have it.
It would be great if anyone could post a picture of that coil pack bracket. Would make it a little easier to fabricate it.
SonicStang
Actually you just need a sheet aluminum and a Dremel tool. The template should look like the one I quickly sketched. I'll give it a try. Just need to find out the exact measurements.
Tornbetween2
Yes they do sell it there. it is $57 from there and $57 from vortech. it would be nice if someone chimed in with the dimensions
Tornbetween2
What size is that radiator hose extension?
Anyone???????????????????????????????????????????????/
Dlm75
