I’m branching off of my earlier thread “fuel rail and vacuum help” to ask about injectors and fuel pumps. A little refresher about my motor and driveline: 347 stroker; Scat rotating assembly; Crane E-cam; AFR 165 heads; BBK 75mm throttle body; fender well cold air intake. Currently running Accel 24lb injectors; stock fuel pump/fuel rails/ fuel pressure regulator/ fuel filter. Stock gas tank. Tremec TKX 5-speed with Ford Performance 3.55 rear gears.
Keeping in mind that I live in CA and have to pass smog every other year, if I go to 42lb injectors, what brands and type? What fuel pump, brands and flow? Different fuel filter needed or recommended? And what about fuel rails? Is stock ok, or ???
Remember: I live in CA so gotta be creative &/or sneaky smart to pull this off ;-)
Upgrades, if visible @ smog inspection, have to appear stock.
Thanks everyone!
Thanks everyone!
