What happens if you run no
Twista
Run no coolant recovery reservoir and cap off the port on the radiator that the recovery tank uses. Will that cause the car to overheat?????
* Sent from tapatalk while sitting on the toilet at work*
RichV
CO
The overflow is there because when coolant gets hot, it expands, and will run into the reservoir at 16psi (cap pressure). As it cools, it will suck the coolant back in the radiator. No air.
If you don't run an overflow, excess coolant will just dump out. Air will then replace it when it cools. Air in the system will cause overheating, which causes more coolant dumped out (as temperature goes up so does pressure) and more air in the system. Eventually you will overheat. May not be right away, but you will.
Why do you ask?
RichV
CO
Cap off the port??? Ya that will be a bomb waiting to explode.
T
Twista
I was thinking the car would explode lol.was just wondering. Working on the car and had to get it home with no expansion tank
Garcimarias
