joser714
- Joined
- Mar 16, 2014
- Messages
- 195
- Reaction score
- 0
I wish I knew what to do. I know I've probably spent close to if not more than a grand in labor. I kick myself in the face for sleeping in my automotive class in high school
hahaI'm proud to say that I have never changed the oil myself on my car in the 3 years I've owned it.
I love taking it to the mexicans and watching them get dirty while I eat my popcorn.
wut kind o seats r does?Hmm..
tubular k-member swap:
First motor swap:
Explorer intake swap:
Converted interior to [mostly] black:
Two headlight swaps, center console swap, installed HIDs, radio install, smog pump delete, complete exhaust upgrade, T5 to TR3500 swap, two clutch changes, U/LCA swap, swapped front sway bar/endlinks/sway bar mounts, changed out rear sway bar, installed aluminum driveshaft, installed lowering springs [twice] changed out oem fuel pump for a 190 lph unit, changed brakes a few times, oil changes, changed out a power steering pump, replaced a distributor, set the base timing God only knows how many times, swapped the stock FPR out for an AFPR, the list can go on...
Things I haven't done:
1] I didn't build or install my 410w
2] I didn't rebuild my TR3550
3] I didn't do my 3.27 to 3.55 gear swap
4] I didn't install my subframe connectors
5] I didn't do any of the ECU tuning
Maximotor sport Caster Camber Plates w/buddy
H&R super sport springs w/buddy
Inner tie rods
Bump Steer kit
Custom Smoked Headlights
Fog lights w/HIDS
K&N CAI
about 100hrs into detailing it over the years
Saleen Rear Spoiler
Saleen Heat extractor hood
LED dash/gear fix
Mach 1 chin spoiler w/best friend
Front Brakes
Sway Bar Bushings
Replacement antenna base
Belts w/ new Idler
Oil Changes
New Mods to be installed:
Bullitt Twin Piston Calipers/Brembo Rotors
Steeda underdrive pullies
C&L Plenum w/ throttle body assembly
New Idler pullies
New Stewarts water pump (needs to be ordered)
New Gatorback belt
Only things I havn't done is fab work. IE, control arms, my exhaust, and so on. Everything else has been done by me
I'm guessing there was quite a bit of fabrication involved to get the seat tracks mounted in there. Does the lumbar work?
I changed the antenna.......
how bout them foglights you bought off me way back LOL
