Im trying to get a throttle body and upper intake plenum for my 1998 mustang gt, there are different brands witch one should i get and what is the difference from 70mm and 75mm and witch one is better or witch one should i get for my car i already have a cold air intake as well.
the size depends on what you want to do in the future....if you plan to stay NA, go 70mm..if you plan to go FI, go 75mm. as for brand, they all see about the same gains...accufab makes a great combo, c&l makes a good plenum, and there is always FRPP throttle bodies.
Oh ok thank you well for sure i dont think im not going to put a supercharger or anything that big so in that cause u say i should go then with 70mm right. but if i dont do anything that big what if i put the 75mm still will it work better or just the same?
eh, I've got the 75mm combo on my car.. It doesn't really matter which you get.. "I" would stick with the 75 regardless of mods..
Ive got an accufab and like it. Heres a little tip though. Before you put it on the plenum take a dremel with a lite abrasive brush and polish the inside. The stock casting is ruff and if you smooth it out it makes beter air flow. You can even take it to a tuner and let him do it. Wont cost much and its worth it.
I heard Summit was selling the Trick Flow plenums for $99... that with a BBK or Ford Racing TB would do just fine.
That's the one I've got... 75mm BBk I've seen pics of the FR TB where it actually starts at 70mm and snakes down to about 67.5mm, so I think that would be pretty much useless.. But if you people are set on getting a 70mm TB, a lincoln aviator TB is actually 70mm and can be had cheap.. http://forums.modulardepot.com/4-6l-2v-tech/94272-alittle-tip-save-you-money-70mm-tbs.html
I bought a MAC 75mm TB (new) and hated it. It stuck from day one. I sold it a week later at a loss. Then I bought an Accufab 75mm cause I knew I was going to put in a SC soon afterwards. I also bought a C&L plenum and then after about a year sold it once I got my KB SC. Accufab is a great piece. Do it right the first time.
Ok Thank You guys i think im going to go with accufab 75mm ill keep u guys post it to see how it went
i was about to metion Prof. Products , i know their intakes suck and their plenum isn't nothing much, but how about the T/B, how can one be worst than the other besides looks? I was thinking of going with the TFS plenum and the P,P T/B
Yea, true most of the time. But, how in god's name can one t/b differ from another to warrent an extra 200 dollars?
The PP one was great on my car, fit perfect. I have heard other things from people though saying theirs didnt.
i do understand that PP has problems with their quality control but that is to be espected since its cheap and from china, but why wouldn't it fit right? would it be that the gasket face isn't flat or something?
Most of the PP TB's seem to be good. I did see a few guys complaining about misaligned holes etc. The casting flash can easily be cleaned up.
