what tire sizes?
Ram000
i just got two 17x9 bullitts w/ the polished rim (for $100!!!) and was would like to know if my 245/45/r17 would fit on them.
also, i'm ordering two 17x10.5 dd bullitts--i don't want a 315, it's too meaty for me. what's the smallest i can fit on a 17x10.5? thanks.
Matt94GT
245 should fit, 10.5 is pretty wide I would say 285 minimum but thats pushing it.   If it were me I would go 265 up front 295 out back minimum.
Dan95-5.0
i would be careful on where you buy your deep dished bullits.
i'm planning on buying 2 DD bullits just like you. ford used 2 different charcoal colors. the newer style is darker and the older ones are more brighter.
trying to find that matching color from the different companys that sell deep dish bullits might be hard to find.
just a heads up for ya
R
Ram000
thanks dan, but i'm going w/ the black dd's w/ the polished rim. the ones i bought last night are silver but i'm painting them.
blackfang
I would not run 245's on a 9 inch rim. They are narrow for that and you will have uneven treadwear as you are stretching the tire to fit.
I am going with 17x9 black bullets up front and running a 255/40ZR17 tire and 17x10.5 DD black bullet w/ a 315/35ZR17
Same size I have, im running BFG DR'S out back 315/35 17
R
Ram000
it seems that 315/35/R17 are the most common tire size for 17x10.5 inch wheels. what are some others you can run besides those?
blackfang
I have 275/50r15 BFG DR's on my 15x10 Weld Pro Stars.
98GTSTANG
245's all the way around on my Machs. Will probaly switch to 265 or 275 when they need to be replaced.
R
Ram000
great, but what size are your rims?
ALITL8
i have 255/40/17's on 17x9's and 315/35/17's on the 17x10.5's. i like the 315's on the rear (looks mean) but im probably going to a 275 up front when its time to change.
g_dogg
i have 245/45/17 on 17x9 .. looks great and works great
Matt94GT
I have 265/35/18s and I wouldnt go any wider in the front since it rubs on full turn or turning on a incline...i think i might even drop down to 255s next time for the front.
98GTSTANG
The wheels are 17x8's (OEM size). I finally got some 275's for the rear and left the 245/45's up front. Feels like it throws the car off balance a little with 45's on front vs. 40's on back. Anyone else notice anything like that???
ALITL8
the number 40 and 45 is a percentage of the width of the tire. if you have a 315/35/17 your tire is 315mm wide, the side wall is 35% of that in hieght. the reason the numbers change is based on width... the 275/40 is equal to or close to the 245/45 in overall diameter/circumference/etc. the main difference in the two is width, of course ;)
here's a good tool for tire size calculation :)
http://www.discounttiredirect.com/direct/brochure/info/tmpInfoTireMath.jsp
wbarter
