My rims are 17x9 with 275s i think they have wrong backspacing and are really tucked in. they do not have little indents for studs to go in on the back. my question is will a 1.25inch MM spacer require me to cut my studs? or will it the spacer be wide enough to cover them? I tryd a shitty 1inch spacer once and studs stuck out a little. please help me out thnx
Whitepony: You won't need to trim the lug studs if you use 1.25" spacers. I had to trim 1 or 2 threads off with my 25 mm (1" almost) H&R adapters. HTH, Chris
