I just changed my front struts, springs and camber caster plates. Sometimes when I make a very hard right turn to the right I hear and feel a popping sound on my driver side front end, not sure what it may be. Did I over tighten the sway bar end links to much on one side? Tie rod? Ball joint, which i did remove the nut to help get the long as hell spring compressors on and off? Or? Thanks.
I put them the coils the same way my old ones came out, yes I did use isolators. It only pops when i make a real hard right turn.
I know I have heard of people having this problem before....let me see if I can find an old thread involving it.
http://www.sn95forums.com/showthrea...u-guys-weird-noise&highlight=suspension+noise Sound similar to that ^^^ Check your ball joints
Thanks I think I will check that ball joint to make sure it is tightened up and sway bar links. No noise today, I'm sure that will change LOL!
