I got mine from www.musclemotors.com it's a little more pricey than what you stated depending on which calipers you choose,but it is a nice COMPLETE kit,with powdercoated,loaded calipers,new brackets,slotted/CC zinc washed rotors,correct banjo bolts and teflon coated/SS lines.
Yea $500 is a little more than I want to spend. But I sent Ford Racing an e-mail to see if there is anyway I could swap the blanks for some drilled and slotted. If not then ill just buy the calipers and get some rotors elsewhere.
I know a guy who has some Baer rotors with like 40 miles on them that hes selling. Ill see if I can get it to like $100 or so. Then lines for like $50-75.
Drilled and slotted rotors are supposed to perform better under extreme braking conditions. The holes help cool and release brake gases from between the pad and rotor while the slots clean the pads so you always have a fresh braking surface.
http://www.stangsuspension.com/store/comersus_viewitem.asp?idproduct=446 They give you the option when ordering.
Do they have just the front? Like I said I can really afford all four corners, plus I dont really need the rears.
+1 Also,you gotta watch what you buy.The reason the Ford kit is so cheap is because the rotors they put in their kit are white box chinese made stuff,same ones you get from AZ or ADVANCE AUTO.They are considerably thinner and the vanes in the middle are thinner.I guess the only plus to all that thin-ness is that they're lighter? :
Just about every site that sells the conversion kit has this same phrase in the description. "This kit upgrades your Mustang's front brakes to the ultra high performance PBR Brake Calipers and Pads, and the 13" Brembo rotors that came stock on the MACH 1 and 2001 Bullitt." Brembo rotors are not the white box chinese made stuff.
