Where do these connectors go? 1998 gt
New York
blackdemon007
Ohio
If the connectors are on the passenger side firewall and the car still runs fine, my guess would be A/C.
The second picture looks like the plug for the evap control valve, the third picture looks like the ground that goes to a bolt on the fuel rail. Im not to certain about the first plug. Is that on the engine harness or the chassis harness that goes around the engine bay?
B
New York
On the third picture i thought it was for the oil pressure switch as i can't find that connector, put the wire is way to short, I cut an spliced a wire in to make it longer, now that you say it might be a ground it makes a lot more sense :/
EDIT**** i found out that the Oil pressure connector is part of the o2 harness
Pitbull_SN95
St.Petersburg, Florida
The top picture is a switch for the A/C. The second one is for the evap system and the third is a ground that goes on top of the fuel rail.
B
New York
awesome thank you, there is also a connector that looks exactly like the one in the first picture but has a brown bottom instead of blue, do you happen to know what that one goes to?
wbarter
